factory fogs no longer light
Old Sep 13, 2006 | 08:05 PM
gbdunn's Avatar
Default factory fogs no longer light
Guys -
Boths (factory installed) fog lamps on the '94 850 no longer light. The Bulbs are ok and I can't find a fuse.
Guessing it is possibly a bad relay. Any ideas where this relay may be located.
Thanks,
gbdunn
Old Sep 13, 2006 | 08:52 PM
Default RE: factory fogs no longer light
There should be a fuse. I remember at one time when I installed a kit I had to install a fuse in the fuse box.
Do you have power there?
Old Sep 14, 2006 | 12:53 AM
gbdunn's Avatar
Tech -
Have gone thru every fuse in the box (under the hood), and all are OK. Any ideas on where else I can look, either for the fuse or a relay?
gbdunn
Old Sep 14, 2006 | 05:46 PM
billofdurham's Avatar
Relay #7 in the central electrical unit is for the fog lamps. Fuse #18 is also for the fog lights.
bond007
Jul 6, 2011 06:44 AM
drizzt05
Oct 7, 2007 07:34 PM
VolvoDriver
Feb 17, 2007 02:35 AM
tupapison
Jul 29, 2006 12:29 AM
becbam
Aug 30, 2005 02:28 AM
