fan quit working fuse is ok??
Old Jan 15, 2011 | 02:12 PM
dlaxdal's Avatar
Default fan quit working fuse is ok??
I have a 1995 850 turbo and the cabin blower quit working. The fuse is ok. How can you tell if it is the Resistor that needs to be replaced. Any help will be much appreciated. thx
Old Jan 15, 2011 | 03:34 PM
boxpin's Avatar
Hard wire the fan to see if it works. The Resistor regulates ground so you just need to make sure there is power on one side of the fan (red) then provide a ground to the other (black) and see it if goes. If so, bad resistor
Old Jan 16, 2011 | 01:36 PM
dlaxdal's Avatar
what do you hard wire the fan too? ANy instructions. thx
Old Jan 16, 2011 | 09:14 PM
boxpin's Avatar
I am a little worried here. How are you mechanically?
The Red wire on the fan should have power on it all the time(with the key on)
The Black wire gets different amounts of ground to it from the resistor.
With that said, if you put a FUSED wire that is connected to ground and touch it to the black wire input on the fan the fan should go provided its not bad.
Old Jan 17, 2011 | 11:52 PM
dlaxdal's Avatar
thx the fan started to work again. I will watch it and go from there. thx
Old Jan 18, 2011 | 01:02 AM
ibified's Avatar
thats not necessarily a GOOD thing. you still have an issue, but instead of it being constant, it's intermittant. That makes things harder to diagnose.
Old Jan 18, 2011 | 07:42 AM
boxpin's Avatar
When my resistor pack went out the fan would shut off when I had it at full speed. It would be dead from there, then if I shut the key off then turned it back on it would work again until the next time. Problem solved when the pack was replaced. This is a climate Controlled system.
Old Mar 27, 2011 | 06:19 PM
dlaxdal's Avatar
Default intermittent blower
The blower now comes on and off at various times and will not shut off. Is this because of a bad resistor? Thank
amazon2
Aug 22, 2015 10:04 AM
dlaxdal
Jan 15, 2011 03:23 PM
tmixdorf
Dec 8, 2010 12:17 PM
tmixdorf
Nov 30, 2010 12:03 PM
rgs4x
May 14, 2009 06:58 PM
