Fault Code 453
Old May 15, 2018 | 08:36 PM
Adam Sinke's Avatar
Default Fault Code 453
I used the diagnostic unit to determine some fault codes. The one that is concerning is code 453. I understand that means there is a misfire on cylinder 3. Would that be a result of a bad fuel injector? I recently had to do an extensive clean and replace on the PCV system which included removing the fuel rail. I didn't replace any of the injectors at the time because I am cheap and this car doesn't mean a lot to me. The fuel injectors came off rusty and obviously warn. Would that likely be the reason for my misfire?
As always thanks for any assistance.
Adam
v1lcins
May 20, 2022 10:53 AM
volvojunkie
Mar 15, 2009 12:35 PM
elchingon2002
Mar 11, 2008 10:41 AM
safari
Dec 10, 2007 07:46 PM
mddavis
Jul 19, 2007 02:36 AM
