First 850
Old Jul 21, 2008 | 08:43 PM
Dninty9's Avatar
Default First 850
I just purchased a 850 turbo. We had a 740 sedan back in the mid 90's that was stolen never to be found. It was a great car so I hope this purchase will live up to the last Volvo. After reading on here I know I have some areas that need attention on the 850. One of the first things I want to fix is yesterday it threw a check engine at me with codes p1310 , p0301. The car has brand new Volvo plugs, cap and rotor and new Bougicord wires with a manufacture date of 09/07. What other things could cause those codes ????? thanks Brian
Old Jul 22, 2008 | 08:40 AM
JimKW's Avatar
Default RE: First 850
Could be many things. When mine threw a P0301 I had a bad valve. Could be as simple as bad wire or plug, even though they are new.
Old Jul 22, 2008 | 02:39 PM
sporky's Avatar
Just throwing this out there without looking up your codes...have you ruled out any vacuum leaks? Stinkin' vacuum leaks can cause a whole slew of codes to pop up.
Old Jul 22, 2008 | 11:54 PM
Dninty9's Avatar
If it were a valve, Would a compression test show that.? What am I looking at in cost to replace valves..?
Old Jul 23, 2008 | 08:31 AM
Psaboic's Avatar
First thing I would do is clear the codes and see if they come back. If they do I would suspect what ever had recently changed (i.e. plugs, wires, etc) as a possible culprit. Go from there.
Please keep us posted. And yes, a compression test would show a leaky valve.
Old Jul 23, 2008 | 08:37 AM
JimKW's Avatar
Bad valve is almost worst case scenario. With worst being piston rings. If compression shows low do a wet compression. If still low it's valves. Start with simplist first though.
djforresta
Jul 4, 2010 11:15 PM
volvomang
Aug 23, 2009 02:13 AM
glkprhog
Jul 4, 2007 02:39 PM
USSEnterprise
Sep 30, 2006 05:49 PM
