fog lights
Old Feb 21, 2007 | 01:51 AM
MattB850in's Avatar
Default fog lights
Can i install aftermarket fog lights to my 850 wagon? i have read some stuff about there being certain wires to lead off of. Or can i buy prewired fog lamps and just run them to volvo fog light switch, or switch the comes with kit.
Thanks
matttttttt
Old Feb 21, 2007 | 05:10 AM
JPN's Avatar
JPN
Default RE: fog lights
Hi matttttttt,
Fog lamps, or any auxiliary lamps can be installed on most cars, as long as they don't block airflow to the radiator. I assume most kits come with wiring instructions, wires & necessary hardware. I would avoid cheap units and go with name brands. I personally like projectors for AUX application. Projectors look nice but are a bit weak for primary source of light. But for fog-lamp application they are great. HIDs are still bit overpriced.
Some shopsinstall it for you, but you can do it yourself if you have a wire stripper, digital multimeter, splicing/soldering tools, and any basic electrical tools.
Good luck,
JPN
Old Feb 21, 2007 | 09:24 PM
If you want to spend time you can use the factory wiring.
If not then just wire the switch from the kit.
Old Feb 22, 2007 | 02:22 AM
m1964's Avatar
You can buy a OEM switch and a wire harness from a dealer, so your dash will look good with OEM switch, then run the harness off ofan accessories plug under the dash (yellow)
rspi
Jan 13, 2012 09:35 PM
SpaceMomMort
Nov 6, 2008 02:02 AM
Volvaman
Jun 26, 2008 04:16 AM
jc740T
Nov 23, 2004 10:48 PM
