Oil
Old Feb 21, 2007 | 03:37 PM
kakins's Avatar
Default Oil
Not sure what type of oil is best for the 850 r. I'm trying to figure out why my oil burnsfaster maybe the turbo or the oil type if any suggestions please let me know. Does anybody know of a good shopin Philadelphia to service my car?
Old Feb 21, 2007 | 10:08 PM
Default RE: Oil
Most like Mobil 1 10/30
Old Feb 21, 2007 | 10:46 PM
RedTurbo850's Avatar
Default RE: Oil
You don't want the oil to burn....
But Synthetic for cars w/ Boost is HIGHLY recommended.
Old Feb 21, 2007 | 10:51 PM
huzzsaba's Avatar
Default RE: Oil
5w30 or 10w30? or is it winter 5w30 and summer 10w30
Old Feb 21, 2007 | 11:13 PM
Default RE: Oil
Varry's on preference.
Someone will be able to help more with the Northern climate.
I am in Florida. 10/30 all year round.
Old Feb 21, 2007 | 11:29 PM
bigmay850's Avatar
Default RE: Oil
where in philly r u i know a good shop right outside of philly in North hills
that my grandfather and mom have been goin to for close to 35 yrs
i work there during summers. It is called Sacco auto Repair
Phone # 215-885-4621
i use 5w30 in winter and 10w30 in summer if u use 10w30 in winter
in may take longer to warm up.
hope this helps!
Old Feb 22, 2007 | 01:43 AM
Default RE: Oil
ORIGINAL: huzzsaba
I think 5w goes down to temperatures of -30F.
It's really unnecessary. No need to spend the extra cash, 10w is fine...And remember, I come from Minnesota so I know cold...
Old Feb 22, 2007 | 03:20 AM
JPN's Avatar
JPN
Default RE: Oil
Last greetings from Chicagoland.
As Tech has noted, oil selection is more of a personal preference than scientific facts. However, I would use 10W-30 for turbocharged engines, unless you live in the Arctic area and mostly do short trips. Once warms up, 10W-30 should suffice and 5W-30 may become too thin for the turbine bearing. But again, using 5W-30 won't harm anything. However, as RedTurbo has noted, I would definitely use either full-synthetic or synthetic-blend for a turbocharged engine. I personally use Valvoline Durablend 10W-30 and the car seems to be happy with it. Even though Volvo engines are noted for may miles of service, make sure to use good quality oil, as their engines are extremely sensitive to the quality & correct quantity of the oil.
In addition, make sure to use either OEM (MANN) filter or equivalent that has check valve in it.
I hope this helps.
JPN
nuclearseal
Aug 17, 2022 01:48 PM
endneu913
Nov 21, 2010 10:53 AM
nationm
Feb 12, 2006 10:09 PM
jeannelw
Nov 18, 2005 10:05 PM
witstaffy
Jul 25, 2005 09:31 PM
