Found a 850 turbo non glt at the yard can i put that turbo in my 94 n/a engine
Old Feb 21, 2009 | 09:41 PM
eddiecortes112683's Avatar
Default Found a 850 turbo non glt at the yard can i put that turbo in my 94 n/a engine
and if so can you guys give me some basic steps and helpful hints in the prosses. should i use the ECU's from the turbo car and put it on my regular 2.4i thank you guys for the help im also wondering about the intercooler or should i order one from ipd?thank uyou guys for the replies
Old Feb 21, 2009 | 09:49 PM
It is ALOT of work to do what you want.
If you really wanted to do it you should buy the entire car and swap everything over.
You will need the motor or custom make parts for the turbo oiling system.
Engine harness
engine computer
exhaust
coolant hoses and pipes
and I bet a few other things I forget at the moment.
Old Feb 22, 2009 | 07:48 AM
bestharry's Avatar
'Buy the whole car and swap everything over other then the body and cosmetics'
But If I were you I will sell mine and buy a turbo model rather then going thru all those sleepless nights thinking about fixing one issue after another next morning.
Old Feb 22, 2009 | 08:35 AM
Default yup
yeah sound like alot of work , im just gonna put it for sale, and get whole new car hopefully i can find a t5. also what is the difference between a glt motor, the turbo,and the t5 ,other than one has 190hp,222hp, 244hp? is it just the psi the turbos make?
Old Feb 22, 2009 | 08:37 AM
The motor has some differences. The compression ratio is different.
But with Mods the GLT can be built up and produce much more power.
rspi
Dec 11, 2012 11:19 PM
TrouperL
1998-2000 model year V70
Oct 30, 2012 01:58 PM
volvo00
May 21, 2011 01:41 AM
ibified
Jun 9, 2010 09:04 PM
jsenge
Jan 30, 2007 09:30 PM
