Front bumper adjustment
Old Jun 29, 2005 | 10:40 AM
sghokie's Avatar
Default Front bumper adjustment
My 850 had the bumper pushed back a little on one side. I guess they hit something obviously.
So the bumper now extends into the wheel well about an inch and sometimes it rubs on the tire.
How can I pull the bumper forward?
Old Jun 29, 2005 | 07:53 PM
Default RE: Front bumper adjustment
You should try to get yourself a used new bumper support.It is just a big aluminum bar that bolts to the bidy of the car.
Old Jun 30, 2005 | 11:59 AM
sghokie's Avatar
is that easy to replace?
Old Jun 30, 2005 | 12:17 PM
It is pretty time consuming.
If you look from underneath there is a bolt on each side that goes from the bottom of the car up.That loosens the bumper.Make sure all the rivets are out in the wheel well area then it will slide off.
Then you will have to play with the tabs to release the cover from the aluminum support.
bedivere66
Nov 20, 2014 05:10 PM
nextproject
Nov 16, 2009 07:04 PM
shadowlord
Apr 8, 2008 09:16 PM
scottiedog
Apr 19, 2007 08:56 PM
danielribo
Jul 5, 2005 07:47 AM
