front suspesion problems
Old Apr 23, 2005 | 11:55 AM
moet32's Avatar
Default front suspesion problems
Hi
I have just replaced my front suspension (struts, springs, control arms, sway bar links on my 96 850 2.5.
I now notice a wobble under acceleration which wasnt there before,
I have also replaced front engine mount aswell as top and bottom tourque mounts,
The wobble is still there Help!
What else can it be..CV joints? or have i done anything wrong while fitting new parts.
thanks
steve
Old Apr 23, 2005 | 02:43 PM
Ocotillo's Avatar
Default RE: front suspesion problems
Have you had it aligned? Doing that much front suspension work will require an alignment afterwards. also , I'd double check everything to make sure it's tightened to specs.
Old Apr 23, 2005 | 03:06 PM
moet32's Avatar
yep had it all aligned at garage
At first i didnt tighten the control arms to chassis bolts loaded only later i lossened and retightened again loaded.
would this matter
Old Apr 23, 2005 | 04:17 PM
Ocotillo's Avatar
Boy I don't know other than maybe the springs need to "seat" or something. Take a pry bar and check everything.
And even since retightening the control arms does it still wobble?
Old Apr 24, 2005 | 03:31 PM
Make sure the inner tie rods aren't worn and the balljoints.
Does it just pull from side to side slightly?
Old Apr 25, 2005 | 02:57 PM
moet32's Avatar
tie rods do you mean the sway bar link rods
if so ive replaced these
could the cv joints have been damaged during the process of replacing parts.
or could the two gearbox mounts cause this effect if they are shot
how can i tell if joints are gone they dont creak or crack..
thanks for help
steve
Old Apr 25, 2005 | 05:23 PM
The tie rods are on the steering rack.With the car off the ground or just the front wheels off the ground.Try wiggling the tire from front to back and up and down and see if there is any play at all.
Are you sure it isn't torque steer?
Nathan Forder
Dec 16, 2014 01:05 AM
philipm
Sep 16, 2011 01:57 PM
lister99
Jul 5, 2008 01:29 AM
booyaolian
May 24, 2008 01:37 PM
scottiedog
Apr 19, 2007 08:56 PM
