Front tire noise
Old Feb 25, 2012 | 11:07 AM
bill dixon's Avatar
Default Front tire noise
Hey guys I am new to this Forum I have a 1995 850Glt and the front drivers side tire has a loud hum while driveing it.We haven't drivin it in awhile and want to fix it so my wife can start driving it again.I think is the front wheel bearing hub and I looking in the right dirrection.we love this car its good on gas and fun to drive.Thanks for the help.I have replaced these on my other car and truck.
Old Feb 25, 2012 | 02:47 PM
amarlow2002's Avatar
sounds to me like the wheel bearing is a good starting point. Had a hum in the front of my '04 S40, changed the wheel bearings and problem solved. good luck
Old Feb 26, 2012 | 07:28 AM
bill dixon's Avatar
Thanks Amarlow2002 for the reply do you know if I need to buy any new seals when I replace the hub bearing.I want all the parts on hand when I pull it apart.thanka Bill
Old Feb 26, 2012 | 07:40 AM
I'm not sure what the hub design is on your car. Mine had to be pressed out and in. If this is the case make sure you get new lock rings as you will probably destroy the old ones taking them out. If the entire hub onbolts then it is a simple swap.
tahafisaka6
Aug 29, 2011 10:03 AM
heyitsomid
Oct 11, 2008 06:46 AM
HummerGuy
Oct 10, 2008 08:02 AM
kcw12
Jun 10, 2008 08:48 PM
daisydaisy
Jan 26, 2006 11:52 PM
