Front Wheel Bearing replacement
Old Oct 12, 2005 | 04:34 PM
swede850T's Avatar
Default Front Wheel Bearing replacement
Hello Forum!
Been a while since my last post -- which is a good thing, as my transmission (I thought) problems were cured by the ignition switch! My question now is that the front right wheel bearing is making noise -- how hard is it for the average joe to replace? Also, on the left side, I have a slight thunk over some bumps and the car feels like it slides slightly if I'm coming to a stop and run over a pavement shift. Any ideas there?
Thanks!
Old Oct 12, 2005 | 09:35 PM
Default RE: Front Wheel Bearing replacement
The wheel bearing is pretty easy. When you are ready to tackle it let em know and I will walk you through it.
For the clunking check the upper spring seats.Get a 13/16 Wrench and try to turn the nut on the top of the strut.If it turn the spring seat is bad. If it feels rubbery then it is good.
Old Oct 13, 2005 | 02:38 AM
swede850T's Avatar
Thanks, Tech, I'll check that in the daylight!
One of the links that you included on the 'general' page has wheel bearings for about $100 -- that seems pretty good. What do you think?
Old Oct 13, 2005 | 09:26 PM
$100.00 is pretty good.
If you need more help just let me know.
Old Nov 3, 2005 | 02:23 AM
swede850T's Avatar
Well, my brother, (the bona fide mechanic) replaced the ol' wheel bearing at the shop. So, that helped -- next are the ball joints, are those pretty easy? I had an old Saab 99 that took about 15 minutes to do in the driveway -- how are these in comparison?
Old Nov 3, 2005 | 08:26 PM
Depends of the year the newer one you need to replace the entire lower control arm. But then again it is only about 3 to 4 screws.
Old Nov 4, 2005 | 02:22 PM
swede850T's Avatar
Well, I checked the vin and the last six start with 026 -- so it looks like I can get the ones at FCP Groton, that are pretty reasonable.
Thanks again for your expertise.
Old Nov 4, 2005 | 09:29 PM
No problem!!
oovvutt
Sep 22, 2014 12:50 PM
oragex
Jan 4, 2014 01:26 PM
rspi
May 21, 2013 10:15 PM
rangerjoe0202
Oct 29, 2009 06:47 AM
