Fuel injectors
Old May 5, 2008 | 09:26 PM
lister99's Avatar
Default Fuel injectors
I'm doing the pcv repair on my 96 850 turbo. I've removed the fuel rail and injectors. Is there anything I need replace before reinstalling them, or any particular way I should clean them. They came out easy and just look a little dirty.
Old May 5, 2008 | 10:52 PM
info2x's Avatar
Default RE: Fuel injectors
It is recomended that you replace the o-rings and seals on the injectors.
[align=left] [/align]
Old May 5, 2008 | 10:53 PM
Ozark Lee's Avatar
You can actually service the PCV without removing the rail.Since you have removed it, replace the O rings and the caps that go on the end of the injectors. If you wind up with Beck Arnley replacement partsthe caps need to click twice before they fully seat and they still look funny. It may be the same with the Bosch caps but the only ones I've changed were on my daughter's PorscheI used the Beck Arnley replacements from Advance Auto Parts. I think they are the same Bosch injectors on both cars.
...Lee
Old May 6, 2008 | 07:34 AM
Psaboic's Avatar
Definitely the seals/o-rings. Check very carefully for any leaks at the first start up after installation.
Old May 7, 2008 | 10:39 AM
lister99's Avatar
Can I clean the injectorswith carb cleaner and a toothbrush?
I ordered the o-rings fro fcpgroton.
What is the torque spec on the intake manifold?
Old May 7, 2008 | 04:49 PM
Quick Brick's Avatar
Hey now,
Try this. Hope it helps you out.
[sm=icon_cheers.gif]
[IMG]local://upfiles/14053/1855D3F88B5B437FA5B8AA3155455A5A.jpg[/IMG]
Old May 8, 2008 | 06:18 AM
lister99's Avatar
Excellent.....Thanks QB
Old May 8, 2008 | 06:33 AM
Hey now,
It never hurts to help, unless she's really cute, and he's really big .
I bought the manual not too long ago and if there is anything else I can do, let me know and I'll scan and post as needed.
Old May 12, 2008 | 09:18 PM
Hey now,
What's the word? Any results?
pinegrovedave
Apr 21, 2014 01:44 PM
Vmax
Apr 7, 2014 07:42 PM
J Taylor
Apr 12, 2006 09:31 PM
robmcconnell
Nov 6, 2005 09:25 PM
240GL38751
Aug 5, 2004 03:25 AM
