Fuel Odor - I Suspect the EVAP System
Old Apr 26, 2009 | 05:55 PM
denver005's Avatar
Default Fuel Odor - I Suspect the EVAP System
After a full tank of gas and driving just about 10/12 miles, the needle on the fuel gauge is already 2/3 away mm from the full mark. Additionally, I frequently smell gas when the car stops at lights, etc.
I suspect the EVAP system or the connections to the EVAP system. I checked the fuel lines/and the rails. Did not notice any leak.
If available, can someone post a block daigram of the EVAP system? My vehicle is a 1996, Volvo 850 Turbo.
Thanks in advance.
R
Old Apr 26, 2009 | 07:07 PM
denver005's Avatar
Found one on the Inet.
File Type: zip
Old Apr 26, 2009 | 08:07 PM
Usually it is a hose from the filler neck to the tank.The hose usually cracks.
Old Apr 26, 2009 | 09:16 PM
denver005's Avatar
And this part can be accessed from the trunk? I have opened the cover plate of the fuel pump before.
Where is the EVAP hose connection to the tank in relation to the fuel pump? Can this hose be inspected from the trunk?
R
Old Apr 26, 2009 | 09:19 PM
Most of the evap system can be seen from under the car.
The hose I speak of can be seen from under the car and through the fuel pump hole.
Old Apr 30, 2009 | 03:38 PM
huzzsaba's Avatar
The hose that tech is kind of in a S shape. the diameter one one side is bigger than the other side. One side goes to the tank and the other goes to the big hose that runs with the main fillup hose.
Most probably you will have to drop the fuel tank partially to replace it. I will probably be replacing it tomorrow. I will keep my camera with me to take some photos of the job.
I have the same fuel smell and its worse when the car is still and when the temp outside is above 60 degrees. This is a common problem on the 850.
Old Apr 30, 2009 | 07:06 PM
Unless the clamp is really far off there is no need to drop the tank.
Old May 1, 2009 | 12:57 AM
huzzsaba's Avatar
Hmm,
I hope that is the case with mine. I would love not to drop the tank. So the hose that cracks is the biggest hose I would see under the fuel pump cover right?
Old May 1, 2009 | 07:31 PM
Yes it should be.
Old May 2, 2009 | 11:13 AM
huzzsaba's Avatar
So I replaced the hose yesterday. I wasnt able to take photos however.
I tried to to get at it wthout dropping the tank, but was not able to because of the positioning of the clamp. And even if I were able to get the clamp, the new hose would have been tough to get on.
I have a 95 turbo wagon so i have the longer version hose. I only lowered the tank a few inches to reach the top.
Overall a easy job. I didnt even have to lift the car to get the tank down.
Old May 2, 2009 | 01:48 PM
denver005's Avatar
Thanks for the update. Which part of the hose was damaged? can you post photos of the damaged hose?
R
Old May 2, 2009 | 04:37 PM
huzzsaba's Avatar
I threw the hose away but the cracks were mainly near the ends of the hose near were it clamps to the hard line.
Old Apr 18, 2010 | 07:36 PM
Paul Bohlig's Avatar
What is the name or part number of the hose. I could not locate it on Groton foreign car parts. Where did you buy the one you replaced on the 850 turbo wagon?
Thanks
Old Apr 28, 2010 | 12:14 PM
PerthX's Avatar
I seem to have the same problem. I called customer service @ FCP Groton and the fellow there confirmed that we can't find the hose on their website but that they do have it, #3531434 cost of $13.17. That is the part# and price$ he quoted me for my '95 850T...you may want to call and verify for your particular model.
Old Apr 28, 2010 | 05:16 PM
TED850t5r's Avatar
I had a similar problem.
Bad vent hose on top of the tank, only way to fix, drop the tank. Can't even see this hose thru the pump access cover. Eaiser if the tank is almost empty.
If you disconnect the vapor line connection at rear of the engine cradle, and blow into it, you will know if there is a leak.
The hose is larger at one end, so standard hose won't work unless you get creative.
analogies
Jul 14, 2013 01:29 AM
nemotode
May 25, 2013 10:59 AM
amazon2
Dec 20, 2011 11:17 AM
LoveMyWagon
Apr 18, 2010 04:07 PM
colgate41
Oct 26, 2005 08:28 PM
