Fuel pressure regulator swap?
Old May 16, 2013 | 04:09 AM
Chrispy_T's Avatar
Default Fuel pressure regulator swap?
I dug around the web for some tweaks and mods and ran across a fuel pressure reg upgrade to a 4 Bar from a 2.2L Dodge turbo. I'm finding some that look awfully close but they don't have the bracket to bolt them down and they have a hose fitting where the stock Volvo reg has an o-ring to fit the rail. Has anyone done this successfully here who could help me out with this?
Old May 16, 2013 | 11:59 PM
Chrispy_T's Avatar
Bumping
Old May 17, 2013 | 09:46 AM
boxpin's Avatar
Why are you doing this? It will gain you nothing unless you need the pressure. I am still running the stock regulator.
Old May 17, 2013 | 03:26 PM
I'm running the BWD 22823. Bolted right in. There is no benefit to doing this unless you're running E85 (I am) or you have a bigger turbo (I do). I dropped it in when my engine was still stock and there was no noticeable improvement in anything but then there was no noticeable detriment either. Idled, accelerated and gas mileage didn't change.
1988 Dodge Daytona 2.2L FI Turbo 4cyl
55 PSI / 3.8 bar
AIRTEX ENG. MGMT. SYSTEMS
5G1075
BOSCH
0280160260
BOSCH
280160260
BWD AUTOMOTIVE
22823
CARQUEST
PR7
DELPHI
FP10036
ECHLIN
219578
GP SORENSEN
800-121
KEMPARTS
143603
NAPA
219578
NIEHOFF
22823
WELLS
PR306
Old May 17, 2013 | 05:55 PM
Chrispy_T's Avatar
The whole point is to do the minor upgrades now while I don't have funds for the upgraded turbo and once I do upgrade, I'll have the minimum supporting components. I'm looking at a 16T at least since I'll be flashing the ECU down the road anyway. Fuel cut at 14 is annoying.
MntnDewMan
Apr 3, 2024 04:05 PM
slsnumber1
Mar 15, 2011 02:55 PM
Buck
Dec 28, 2005 01:28 AM
cdunning
Dec 28, 2005 01:27 AM
cdunning
Dec 27, 2005 02:58 AM
