Fuel problem
Old Jul 14, 2011 | 09:41 PM
CajunPaul's Avatar
Default Fuel problem
Okay my fellow Volvo-ers. I have a 1997 Volvo 850, non-turbo. Not getting fuel. Fuel pump was not coming on. Changed that and filter. Fuel pump now comes on. Still no fuel to the throttle body. Plugged in noid light to injector -pulsed. That should rule out cam/crank sensors? Can get vehicle to start by spraying starter fluid in tb. Dont have a fuel pressure gauge so cant check that yet - am I missing something? I'm thinking now, maybe I got a bad pump? Or is there a sensor or some regulator I am missing that may be the problem.
Here is the history of the problem, in case that helps. Car was running fine. Son drove to store, turned it off, came back out - it cranked but ran very rough. Called me, I drive out there, and then it just wont crank. No doubt it was fuel related, so I went through the above processes. I have to be missing something please help thanks
Old Jul 15, 2011 | 12:07 AM
gdog's Avatar
Lack of fuel pressure won't keep the starter from cranking. Does the engine turn over (crank) or not?
How do you know you don't have fuel to the rail if you don't have a fuel pressure gauge? I think Autozone loans them out if you don't want to buy one. Is this a used fuel pump you put in?
Old Jul 15, 2011 | 07:07 AM
Wont crank = You turn the key and nothing happens, dead .
Wont fire = You turn the key and the car tries to start but will not. Turns over and over and over.
Turns over = Starter engages and you can hear the car trying to start.
Old Jul 15, 2011 | 11:01 AM
CajunPaul's Avatar
Sorry all - guess I didnt give enough info - and thanks for replying. The car turns over and over but will not fire. I checked for fire and I have spark at the plugs. I checked for fire at the injectors using a noid light and I have pulse. I can get the car to start with starter fluid.
Old Jul 15, 2011 | 08:54 PM
CajunPaul's Avatar
Default Problem fixed
Thanks to the responders but the problem has been fixed. Rookie mistake - I put the new pump in wrong and the lines were crossed!
smithnr
Apr 8, 2013 04:56 PM
orcutd
Sep 27, 2008 08:13 PM
the_happy_driver
Jun 26, 2008 12:47 AM
chaniewski
Nov 13, 2007 05:50 PM
edahlgren
Oct 7, 2005 09:53 PM
