Fuel pump relay interchange?
Old Dec 25, 2008 | 10:58 AM
Brian Mc's Avatar
Default Fuel pump relay interchange?
1993 850 NA- are all the fuel pump relays the same on these? I have a green one PN89-8709-000
I have seen them on ebay- different colors and part numbers- but the pinout and base all look the same!
I did a search and couldnt find an answer- can you help?
Old Dec 25, 2008 | 11:19 AM
Ozark Lee's Avatar
Default RE: Fuel pump relay interchange?
They all interchange and function just fine. I have swapped the red ones for the green ones and visa versa.
...Lee
Old Dec 25, 2008 | 05:56 PM
JimBee's Avatar
Lee,
Is the fuel pump relay the same on '93 850's as for '94 and up, and on turbo and non turbo? Is it also the same on other models of those years?
Thanks,
JimBee
Old Dec 25, 2008 | 09:45 PM
Ozark Lee's Avatar
I'm running one that I rebuilt that showed a date code of June 1993 in my 1996 turboand it works fine so I would say yes - I think they are all the same functionally. They may be different at the component level but they do the same thing when they are plugged into the socket.
...Lee
spidersilva
Aug 17, 2011 07:23 PM
montysano
Sep 9, 2008 11:52 AM
madhatter
Dec 7, 2005 06:00 PM
crazypixie
Jan 22, 2005 01:01 AM
