fuel pump removal
Old May 6, 2007 | 07:31 PM
moonraker's Avatar
Default fuel pump removal
I have an 850 estate and the fuel pump needs replacement, how do you disconnect the fuel lines.
I have seen a thread that says to disconnect the "quick release" connectors, how exactly do you disconnect them.
Cheers Steve
Old May 6, 2007 | 08:47 PM
RedTurbo850's Avatar
Default RE: fuel pump removal
You need to pry them upwards.
Edit: Post #35 was my post on the directions. They are very good directions but if you need help let us know.
https://volvoforums.com/m_57785/mpage_4/key_/tm.htm
Old May 8, 2007 | 02:36 AM
BriGuy's Avatar
Maybe this is a silly question, but can you get access to the pump through the floor in the 850 wagon?
Old May 8, 2007 | 02:38 AM
^What do you mean?
Look at that link I posted because one of the links is instructions for wagons (but it applies to sedans equally.)
If you pull up the matting in your trunk, you will see a circular metal thing on the passenger side. Underthere is the pump.
Old May 8, 2007 | 02:45 AM
BriGuy's Avatar
Sorry, must have missed that part.
Old May 8, 2007 | 03:47 PM
^No problem.
Did you find it?
Edit: Find the fuel pump location I mean..
Old May 8, 2007 | 04:50 PM
BriGuy's Avatar
Yep found it - it was one of the other links within your directions. I hadmy fuel pumpreplaced about a month ago ($600!). I usually do all the work myself, but it died on the way to work so I had to have it towed somewhere. That somewhere was an import place down the street, I noticed the last couple times after I filledthe tankup completely it smelled like gas. The bozos at the shop didnt even tighten the ring down - I tightenend it by hand thenused a screwdriver to tap it tighter, guess I'll stay away from that place.
Old May 8, 2007 | 10:16 PM
^Wow....If you could tighten it by hand that is VERY loose.
It's supposed to be 30 (I forget what the unit is called). But it's 3x what you can do by hand is the recommended tightness.
spidersilva
Aug 17, 2011 07:23 PM
tater
Mar 3, 2010 09:00 PM
s_moneh
Nov 30, 2009 02:03 PM
pirate240
Aug 2, 2006 11:21 AM
