gauge lights
Old Feb 23, 2006 | 03:06 AM
cool_kyle_3000's Avatar
Default gauge lights
the lights for my gauges are going hay wire. The light for them is not burned out and works fine. But when i am driving down the road it shuts off and when i turn the headlight switch from the on position to the off position and back they come back on and stay on for how ever long it feels like. I dont know what is causing this.
Old Feb 23, 2006 | 03:54 AM
sandders08's Avatar
Default RE: gauge lights
do u think it could be the switch? or maybe some wirings are loosely connected to the gauge. the headlights are fine i guess...
Old Feb 23, 2006 | 09:08 PM
Possibly the headlight switch.
Have you had the recall done?
Old Feb 27, 2006 | 04:01 PM
there was a recall. I wasnt aware of this.
Old Feb 27, 2006 | 09:39 PM
Stop by the Dealer with your Vin# and see if they can look for open recalls.
Old Feb 27, 2006 | 10:12 PM
NSF Ed's Avatar
This will sound really bizare but, check the tail/brakelights. I had a 94 Mercury Villager that had strange things happening with the dash lights and the cruise control. It turnred out to be one of tail/stop lights where the two small metal contacts for each filament had been indented and spread out so much over time that they touched. So when I put on the lights the stop lights came on, the cruise control cut out, and the dash light went out. Also when I hit the brakes the tailight sort of came on. I don't know if your car has the dual filament bulbs or if stop and tail lights are all separate but it's worth checking.
Old Mar 6, 2006 | 06:53 PM
ill give that a try but this week it worked fine and then after like 5 days it started doing this again. It sucks then it is pitch dark out and u cant read the gauges.
Old Mar 10, 2006 | 04:13 AM
and then today the lights went off and then on for abput 5 minutes sometimes going out and then just gettin darker.
ibified
May 26, 2011 01:03 AM
bartman
Sep 2, 2008 01:46 PM
BlacknRedGT
Oct 3, 2005 09:50 PM
