grinding sound when coming to a stop
Old Oct 11, 2011 | 10:21 AM
jonhall's Avatar
Default grinding sound when coming to a stop
brake pads look fine, the guy i bought it from said he just changed em, but he didnt mention the rotors....worn out rotors causing the grinding sound?
Old Oct 11, 2011 | 10:38 AM
MattyXXL's Avatar
Grinding is usually metal to metal..
Remember you can only see the front of the rotor...
You need to pull all the wheels and check for yourself, Dont go on what someone told you.
Old Oct 11, 2011 | 11:05 AM
You can usually feel if the pads are gone as well.
Old Oct 11, 2011 | 11:39 AM
Never trust anyone who's is selling you or sold you a vehicle. Yes they may be perfectly honest to a fault then again they may get you killed.
Pull all the wheels and take a look at both sides of all four. If you're getting a grinding sound when you apply the brakes it pretty much has to be that one of the pads wore out. Maybe it has new pads because there was a problem that wasn't fixed but just covered up by new pads. If a caliper gets hung up and no longer "slides" or floats it will eat the inside pad quickly but leave the outside pad (the one you can see through the wheel) looking good. That's the problem with someone saying they did a brake job. Was it just a pad slap where all they did was push the piston back and replace the pads (poor quality job) or did they clean and lube the caliper slides, crack open the bleeder and then retract the piston discarding the fluid in the caliper rather than pushing it backward into the ABS and master cylinder. Did they replace the rotors or have them turned so the pads have a flat smooth surface to grab a hold of? This is what you need to find out.
Old Oct 11, 2011 | 08:44 PM
I just read another post that I guy complained that cheap after market pads were making grinding noises.
Old Oct 11, 2011 | 10:25 PM
jonhall's Avatar
im well aware to not trust what somebody says, which is why i said i checked em and they looked fine...
whats a good/decent brake pad and rotor for these cars...the car is not a main source of transportation, but i still dont want the crappiest...
Old Oct 12, 2011 | 06:45 AM
I'm running Wagner Thermo quiets without any problems.
Old Oct 12, 2011 | 08:13 AM
Default What's a good brake pad to use???
Originally Posted by jonhall
What's a good/decent brake pad and rotor for these cars...the car is not a main source of transportation, but i still dont want the crappiest...
Anything you find on www.iPdusa.com would be good.
Jul 26, 2015 11:14 AM
dman777
Nov 28, 2012 06:24 AM
Rich Ard
Oct 14, 2010 01:43 PM
DerekSmalls
Apr 6, 2009 06:47 PM
msennett
Suspension
20
Sep 13, 2008 11:30 AM
