Ground G901 Location
I'm not looking at a wiring diagram right now just going from memory. It may be the ground located on the fire wall if I remember correctly.
I think I found the one you're thinking of. It's not the one, it's a strap right off the engine block.
This is the ground for the
blower fan relay (w/o ECC)
climate control panel (w/o ECC)
program selector switch (w/ a/t)
left/right rear heater seat switch
left front door lock
left/right front heated seat switch
power window switch
electronic climate control module (w/ECC)
blower fan control module (w/ ECC)
power sunroof control module
blower fan motor
right power door mirror
driver/passenger in car temperature sensors
p-shift lock solenoid
cigar lighter illumination
gear selector illumination lamp
rear ashtray illumination lamp
right vanity mirror lighting
on board diagnostic connector
Most of those things don't work on the car.
power window switch
blower fan motor
The is the ground for
power window switch
blower fan motor
Problem is most of those things aren't working.
Just can't find this ground
power window switch
blower fan motor
