Guages dead after Evap Replacement
Old Sep 5, 2006 | 12:50 AM
gregf's Avatar
Default Guages dead after Evap Replacement
I expect I have a plug out but would appreciate thoughts on where to start looking. I have some lights on the switches outside the gauge cluster but nothing in it and no warning lights.
And on the a/c lines, do they just push together? Seems too easy or too weak.
Old Sep 5, 2006 | 07:18 PM
info2x's Avatar
Default RE: Guages dead after Evap Replacement
Did you drive around at all? I noticed that when I did some work on my car I needed to go faster than a specific speed for the guages to come back.
Old Sep 5, 2006 | 09:16 PM
There is mainly one plug that feeds everything. But depending the older cars may have one extra.
The lines just push in as long as they lock then it will be fine.
Old Sep 5, 2006 | 09:29 PM
gregf's Avatar
The good news is we're blowing 42 degrees with no detectable leak. I also broke the linkage arm coming off the recirc motor. It's cutting in to my $1200 savings. I'll report back on the guages. Hopefully that won't cost me.
Old Sep 5, 2006 | 09:58 PM
The arm should only be a couple of Bucks.
Double check the plugs under the drivers side of the dash.
Leej
Mar 15, 2021 08:28 PM
Ashton391
Oct 13, 2011 08:21 AM
painthunter9
Interior
Sep 11, 2008 11:49 PM
Ratphink120
Aug 16, 2007 10:03 AM
undauntedgsx
Mar 25, 2006 02:53 PM
