H&R coil springs
Old Mar 22, 2012 | 10:07 AM
  #21
boxpin's Avatar
Originally Posted by slimflex2
@boxpin, is the first picture after you installed the H&R coil and the second after you cut the coil to drop it a lil bit? and how was the ride after your installation.was there an improvement in ride and handling?thanks
The second picture is the same day, right after installing the springs. The only difference is where the sun was during the day. When they were installed I was running stock shock and IPD sways.
Do I notice bumps, yes, but not terribly bad. Just felt like I had stiffer springs. Your not going to lower your car and have a Cadillac ride.
The big difference was when I went from OEM shocks to Bilstein sports. Whole new world opens up. I dont have the squatting and floating over bumps anymore, its precise and controlled.
For altering your suspension, if your after looks get the springs first. If you after performance get sway bars first.
Old Mar 25, 2012 | 07:00 PM
  #22
izinux's Avatar
Did you feel the sway decrease with stock struts but upgraded springs ? I just replaced the struts because one went out after I bought the car and now I regret doing them because I'm finding my self wanting to invest money into the car but dont want to turn around and upgrade the struts and loose $600.
Old Mar 25, 2012 | 11:20 PM
  #23
boxpin's Avatar
Yes a bit but the blunt of the control comes from the bars and the springs. The shocks only provide that initial hit.
Old Mar 26, 2012 | 01:58 AM
  #24
izinux's Avatar
So you would say strut bars and springs should give me a noticeable handling increase ? And did you have to change the chamber and cast I want todo 1.6 drop but I dont know if I need to change alignment.
Thanks for all your help
Old Mar 26, 2012 | 10:30 AM
  #25
boxpin's Avatar
Springs and Sway bars, not a strut brace will be very noticeable. When I added the strut brace later, that was noticeable too. But springs and sway bars the most obvious.
RGHamilton57
Jun 29, 2015 08:22 PM
Ricardito
Aug 14, 2012 08:29 PM
johnboy1967
Dec 14, 2004 08:22 PM
