Headlight lens replacement
Old Apr 7, 2008 | 08:53 AM
mnvolvo's Avatar
Default Headlight lens replacement
I have a seriously cracked headlight lens only my 1995 850 wagon and am looking to replace it. Does anyone have a good method for removing the old one and replacing it? It looks like there are some clips that snap on between the lens and a rail of some sort. Can I just pry those off? I'm worried about snapping them. Any and all help would be greatly appreciated.
Old Apr 7, 2008 | 08:55 AM
axelm's Avatar
Default RE: Headlight lens replacement
You shouldn´t have any problem taking those clips off. I am assuming you have taken the whole headlight assembly out of the car, right?
Old Apr 7, 2008 | 09:29 AM
JimKW's Avatar
I've done it on two of my cars without a problem.
Old Apr 7, 2008 | 09:48 AM
mnvolvo's Avatar
No, I wasn't sure that I was going to have to take the whole assembly out of the car. I was hoping to just be able to swap the glass with it still on the car.Do I need to take the whole assembly out toswap the lenses?I suppose I should find myself a repair manual and see if it is in there.
Old Apr 7, 2008 | 10:03 AM
axelm's Avatar
Taking the assembly out is very easy. Is it the left side or the right side?
Old Apr 7, 2008 | 10:04 AM
mnvolvo's Avatar
It is the left (driver's) side. If I take it out, do I need to worry about realigning the headlight beams?
Old Apr 7, 2008 | 10:16 AM
axelm's Avatar
I suppose so. You can do that yourself too. It´s not like you are calibrating a laser beam.
Old Apr 7, 2008 | 10:27 AM
JimKW's Avatar
It comes out very easy and then you dissassemble it and replace the lense. Getting the rubber seal back on was the toughest part if I remember correctly.
Shel1555
Jun 17, 2012 03:31 AM
cb1313
May 23, 2009 11:49 AM
cb1313
May 16, 2009 08:35 AM
GolfGuyatWork
May 22, 2008 03:29 PM
banani
Sep 21, 2005 10:19 PM
