Heater fan resistor
Its an easy job but you might want to check your vin...I believe there are different resistors for the 850's.
Remove the torx screws and take out glove compartment and kick panel. You will now see a black knee bolster. Remove the three bolts I believe is 13mm, I always forget sorry. Just to the left of blower motor casing you will see a black casing being held on with a single torx screw. Unscrew and unplug wire.
Just a note, that to the bottom right of the resistor you will see another small wire plugged in. Unplug that and it makes it easier to take resistor out.
Gluck
Gluck
