Help! Bad Tranny?
Hello -- I just bought a '94 850TW. I got it knowing that it had a problem running (rough idle, intermittant stalling -- but with a rebuilt tranny, 193,333 mi) Since, it's been tuned up (runs great), but now the tranny does not come out of "Winter" mode. At stop lights, it starts out in second, therefore, it's very slow -- sounds like I'm new to manual trans. and burning the clutch. The "winter/summer" switch has been replaced, but to no avail. I push down the winter button and nothing happens, no indicator light, no change in performance. What can I do? [:@]
You need to pull the codes in the engine and the transmission.When there is a code in there it goes into limp home mode and does that till the codes are clear.
You might have a bad Park Nuetral position switch (PNP).
Check in the general section I made a post for links.There is one there that will tell you how to pull the codes.
A1=transmission A2=Fuel system A6=Ignition system.
Check the codes and clear them and see what happens.
The link is something like OBDI codes
You don't need a scanner!!!
Follow the link and it will tell you how to pull codes.
http://www.troublecodes.net/Volvo/
OK, well, mine has OBDII under the change holder, and my brother hooked up his scanner. We got a code P0130. Is that it, or do we have to look at the OBDI boxes in the front right portion under the hood for any codes there?
Thanks so much for your help, thus far, you are a valuable resource!
--Mike
--Mike
I checked the OBDI A1 socket, and it was kind of sporadic. I really couldn't get a read. What I got was a 5-1-1. And according to the table from the website link you posted, that say o2 sensor -- which I believe is not related.
Is there something I'm not quite doing right?
Sorry it took me so long here is a list of the codes I hope you can zoom in on it to read them.
You have to try to figure out exactly which code you have both are on the list.
[IMG]local://upfiles/853/02CFCCB3A1324B55932DD84AA2F99045.jpg[/IMG]
Well, according to the website below, the problem explained matches what mine is doing, (and the codes -- thanks for the code descriptors). The recommended fix is to replace both solenoids. I'm checking with my brother to see when we can get it done. I'll let you know how it turns out.
http://www.babcox.com/editorial/ic/ic40238.htm
Don't know if you've read this, but it breaks out the whole transmission -- pretty useful -- in conjunction with what you've told me.
SABS
Jul 5, 2009 11:11 AM
