Help! Engine wont fire now after spark plug change...
Old Apr 3, 2010 | 09:04 PM
djwhizkid's Avatar
Default Help! Engine wont fire now after spark plug change...
So today me and my pops went out and changed the spark plugs in my 1995 850 GLT. The car has at least 200k miles on it and to my surprise....(and his) the original spark plugs where still in the car all corroded. Well I changed them out with some bosch platinum + plugs that we gapped correctly.
Now my engine turns but doesnt fire? Is it just plugs that would keep it from starting completely? it was starting okay with those old corroded volvo plugs (one of them finally developed a misfire which prompted me to check and change them)
Old Apr 4, 2010 | 12:09 AM
gdog's Avatar
Did you forget to plug something back in, like the coil wire maybe?
Old Apr 4, 2010 | 07:59 AM
djwhizkid's Avatar
We plugged everything back in ...in the same order one at a time...
Old Apr 4, 2010 | 07:41 PM
djwhizkid's Avatar
nobody?
Old Apr 4, 2010 | 08:47 PM
blackbrick's Avatar
Put old ones back and see if it fires. If it does then new plugs are wrong. If it doesn't fire then you may check wires.
Old Apr 5, 2010 | 12:37 AM
TheTrainwreck's Avatar
Yea if it was the same plugs you can be sure it's the same wires too. You probably cracked them all up. They are about 15 years old now. Change the cap too.
Old Apr 5, 2010 | 08:05 AM
JimKW's Avatar
Just cause the plugs say Volvo on them does not mean they are the original. I buy only Volvo OEM plugs when I replace mine. I just have trouble believing the plugs would last 200K miles. It's possible I guess though. Check to see if the plug wires have a date stamp on them. I would definitely make sure you got the right plugs and replace wires, distributor cap and rotor.
Old Apr 5, 2010 | 08:14 AM
djwhizkid's Avatar
I thought about that afterwards since the car was bought from a nice volvo dealer ship. Im sure that they havent gotten a tune up on it since they had it which was in 2003 when it had at least 135k on it (The odometer was broken on purchase). Maybe the dealership happen to tune it up before we bought it but it hasnt been tuned up at all since then (my mother just drove it around without fixing anything)
I have put in a New starter/Radiator/Brake pads/ within the last 6 months. I guess I'm going to do all the stuff you named with a fcp kit...then when I get some more loot the PCV system (pretty sure its clogged)...
I want to get my baby to stage Zero!
Old Apr 5, 2010 | 11:30 AM
You're better off selling your car and getting a turbo instead of putting money into the GLT.
Old Apr 5, 2010 | 07:37 PM
fcpgroton's Avatar
Former Sponsor
If your GLT is NA, sell it and get a T-5 (Turbo)
Old Apr 6, 2010 | 07:50 AM
djwhizkid's Avatar
I wish it was that easy!
Old Apr 6, 2010 | 09:02 AM
JimKW's Avatar
You had any luck getting it started?
Old Apr 7, 2010 | 03:02 PM
djwhizkid's Avatar
No, I feel screwed. I got the regular bosch plugs that the manual calls for and it still wont start up. Either my dad messed a thread or I need to change all the engine stuff wires distributor etc....
just great
Old Apr 7, 2010 | 08:09 PM
bostongrun's Avatar
Default car won't start
You have screwed up the plug wire firing order. You may also have inadvetently pulled the coil wire loose from the dist cap.
The firing order is 1,2,3,4,5 from the timing belt side
The Haynes maual is WRONG the distributor order is 3
Old Apr 7, 2010 | 08:50 PM
confused_al's Avatar
Yup, it is dead wrong.
http://volvospeed.com/Repair/sparkplugs.php
Old Apr 13, 2010 | 08:08 AM
djwhizkid's Avatar
I dont think we changed the spark plug order. we did each one , one at a time. otherwise yes that would have made the most sense. Its just been sitting and my battery is now dead it wont hold a charge. I get paid on the 15th then I'll be able to tow it to a mechanic...
Old May 6, 2010 | 06:34 PM
  #17
djwhizkid's Avatar
I changed the wires today still wont start. going to have it towed to a mechanic....
Been looking for some turbos I found a nice looking s70 1998 turbo for 3500 I wondering if its a good deal....
Old May 7, 2010 | 06:32 AM
  #18
JimKW's Avatar
How many miles and what condition? Less than 150k and good to excellent condition that would be a good deal. They did make the 98 S70 T5 in a five speed. My son has one and that's a nice car if you want a factory five speed.
henrysin44
Dec 9, 2014 09:14 AM
waltonsauto
Feb 1, 2012 10:31 AM
futbolfan15
Apr 2, 2010 09:56 PM
amersue
Dec 31, 2009 04:11 PM
