HELP heater core replaced now temp. won't stay down.
Old Dec 24, 2007 | 09:27 AM
jvcski's Avatar
Default HELP heater core replaced now temp. won't stay down.
ok i replaced the heater core fine. then i filled the antifreeze then ran the car ran fine, then temperature started torise i have gotten all of the air pockets out i think. i am thinking that it might be the thermastat but am not really sure. I am really confused and the rent a car is getting expensive so if anyone has an idea please let me know fast. thank you Jay
Old Dec 24, 2007 | 09:53 AM
green850's Avatar
Default RE: HELP heater core replaced now temp. won't stay down.
by temp you mean the engine temp in your dash?
if so i would go ahead and put in a new thermostat, they are only 5 bucks
my 850 had over heating problems untill i swapped my thermostat out, hope this helps
Old Dec 24, 2007 | 09:57 AM
green850's Avatar
also it can take some time to get all of the air pockets out of the cooling system, so i would try to be patient
Old Dec 24, 2007 | 11:56 AM
b5254t's Avatar
you can try jacking up the pass. side of vehicle with the cool cap off and engine running. that will make it the highest point on vehicle so hopefully the airpocket will bubble out assuming that is your problem good luck.
lamerad
Jan 24, 2022 10:39 PM
ycartf
May 6, 2013 11:19 AM
thegrapist
Apr 15, 2013 03:34 AM
jebb1977@hotmail.com
Oct 11, 2009 05:13 PM
Bruce Wayne
Mar 25, 2009 09:19 PM
