Help!!! Outer c/v boot replacement nightmare
Old Feb 13, 2011 | 11:02 AM
ToOldForDis1954's Avatar
Default Help!!! Outer c/v boot replacement nightmare
This is to anyone who knows how to remove a hub off a Volvo 850 1997.
I have used a gear puller, heat and hammering to no avail, basically I am trying to remove the hub to get to the outer c/v boot and replace it but the hub will just not budge. Heeeeelp!!!
Old Feb 13, 2011 | 11:25 AM
Are you just trying to get the axle out of the hub?
Is it loose in the hub?
Old Feb 13, 2011 | 12:03 PM
yes I am trying to. And what do you mean about loose?
Old Feb 13, 2011 | 12:07 PM
The hub moves the axle. but its stuck in place
Old Feb 13, 2011 | 01:41 PM
Guys this thread is closed. Under extreme pressure I got it loose, found out it was exposed to water and sun.
Rdhcincy
1998-2000 model year V70
May 3, 2012 05:08 PM
72Demon
Oct 22, 2010 02:15 PM
dbarstow
Aug 1, 2010 02:06 PM
andydg
Aug 19, 2007 07:12 PM
info2x
Sep 3, 2006 12:28 AM
