Help ... power steering problem
Definitely check the fluid level first. Actually I would go ahead and replace the fluid. Draw the old stuff out of the reservoir as much as you can with a turkey baster, refill, see what happens. If it is better, do the "draw out/refill/test 2 or three more times and you should have mostly fresh fluid in it.
1st thing I did was to check fluid level then replaced the power steering pump twice with veried results (used pump from wreckers). Now the question is are the pumps any good or is it the rack?
how to test it?
how to test it?
In case you are wondering I still have not got this stiff steering issue resolved, too damn cold right now to work on. However I have to get it on the road soon for my kids to drive the car.
As advised above I :
- checked the fluid
- there is no fluid movement in the reservoir
- belt is good
- replaced the steering pump with a junk yard one (hum .... yup I know!)
Before I get replacing another steering pump, should I check anything else?
thanks
- checked the fluid
- belt is good
thanks
