HELP! SUN ROOF is jammed!
Old May 24, 2010 | 08:25 AM
audis2vato's Avatar
Question HELP! SUN ROOF is jammed!
How can I remove the sun roof to fix it. The mechanism that makes the rear pop open has failed on one side so the sun roof is lopsided and does not close properly. Any tips or advice will appreciated.
Old May 25, 2010 | 08:20 PM
You might have to pull the entire assembly. That is a major PITA.
But first pull the glass and inspect things in there.
Old May 26, 2010 | 08:19 AM
audis2vato's Avatar
Default tech..you say too pull the glass? How?
The very mechanism is somehow jammed. It will go back maybe 6 inches and that's it! How can I get the glass off?
Old May 26, 2010 | 07:28 PM
If you can get it to tilt up there is plastic covers on each side. I think they slide forward. But if you look with a flashlight you should be able to see which way to slide it.
Then you will see the 3 screws on each side to remove the glass. Then you can check some more.
Old May 27, 2010 | 08:19 AM
audis2vato's Avatar
Exclamation As I described it is totally jammed...
It will slide open maybe 6 inches. Tilting IS TOTALLY OUT OF THE QUESTION.
Old May 27, 2010 | 08:59 PM
Then it is going to be a major pain.
See if you can work those covers off then you can unscrew the glass.
Old May 27, 2010 | 09:13 PM
JimBee's Avatar
Default sliding covers over sunroof linkage
I tore the first one up to get it off, not knowing how it was anchored. Volvo uses what I would call rods (or short pieces of plastic rods) that slide into partially open clips. Those covers slide toward the rear, but can be really sticky. The last one I did, I drilled a 3/16" hole about in the middle I think, stuck the tip of a needle nose pliers in the hole, and tapped the pliers with a hammer near the tip where they went into the hole in the cover. Even this took some significant effort before the cover slipped back and released. The one on the other side offered almost no resistance. Once the covers are off, you can see the mechanism. Hope this helps.
BTW: those links dry out and get dirty with road crud. You'll probably want to clean them up including the track they run in, and lightly grease or oil the "cam" link which has metal sliding on metal to lift and position the glass. If its dry it could break like one of mine did.
While you're in there, inspect the seal flange that is laminated to the glass. Over time, water seeps between the glass and the seal and can deteriorate the glue that holds the flange to the glass. When that happens you have a "mysterious" leak, because you can't see why the water getting past the seal isn't dropping into the tray and draining through the hoses. A junkyard glass is probably your best solution if that happens. Of course, once you take the glass out of the junker, it's really a junker after the next rain storm. We drift.
JB
hovonogila
May 16, 2019 02:28 AM
Kess22B
May 29, 2011 08:01 AM
850forum
Sep 30, 2008 05:43 PM
martyne
May 9, 2005 03:06 PM
martyne
Dec 7, 2004 09:58 PM
