help with timing
Old Jan 31, 2010 | 09:24 PM
usa_alex's Avatar
Default help with timing
i know this is my first post but i'm not new to volvo
i have a 1996 850 non turbo with 136xxx miles
i just replaced my valves one of the exhaust valves broke so i was loosing compression in one cylinder
i need help to put my timing belt back up
i removed the camshafts replaced all seals but how do i know now where they shoud be when i put the belt on
any help would be appreciated
thanks
Alex
1997 Volvo 850 T-5 gone
Old Feb 1, 2010 | 08:27 AM
JimKW's Avatar
Did you mark them when you took it apart? Look at the frequently used threads that is a sticky at the top of this forum and you will see where the marks are on the cam and the crank and how to align them.
Old Feb 1, 2010 | 07:29 PM
usa_alex's Avatar
thanks
i read the thread for the water pump and timing belt i know where the marks are on the crank and on the camshafts.
i marked the sprocets where they go an the camshafts, after i removed the camshafts, removed the sprocets for the belt and installed them back with new seals
now i just turn the engine to the mark and line the camshafts to the marks?
thanks
Old Feb 2, 2010 | 08:10 AM
JimKW's Avatar
Make sure you turn the engine over by hand a few times to make sure there is no resistance other than compression. I didn't do this once and bent two valves cause I was not on the marks properly.
Old Feb 2, 2010 | 08:45 AM
usa_alex's Avatar
thanks
7zarc7
Mar 24, 2010 07:17 AM
04v70
Jul 17, 2009 11:01 AM
bcon415
Sep 19, 2008 07:17 PM
Soloracer
Aug 26, 2006 04:43 PM
Qamar
Aug 24, 2005 07:37 PM
