Here's one for ya, what kills an intake valve?
Old Oct 28, 2013 | 10:56 PM
awfulwaffle's Avatar
Default Here's one for ya, what kills an intake valve?
Hello again folks
Just got my head back from the machine shop. Surprisingly, 4/5 cylinders on this 20 year old, 270k mile hunk of aluminum had absolutely no leaks at all. The last one (actually #1), had a small leak. It was also the cylinder into which coolant was leaking due to a blown headgasket.
Right before I left I happened to ask the machinist for the valve which was replaced, and was surprised to see that it was an intake and not an exhaust. I've looked around the interwebs, but can't seem to find an answer as to what might have caused that valve to go bad. Looking at it, there is a small section (about a 60 degree arc) that has what looks to be extremely faint crack-like distortions in the metal. Faint enough that I can't get a picture with my phone camera. However, they don't seem to extend onto the sealing surface. Anyways, any idea what might have done this valve in, and if those little distortions are any kind of indicator?
Looking forward to some insight!
Old Oct 30, 2013 | 01:01 PM
mudpie's Avatar
Just a guess....
Aren't the exhaust valves sodium filled or something? Maybe one cylinder was getting hot (leaking injector or something?), and the exhaust valves were able to withstand the heat but the intake valves weren't
Old Oct 30, 2013 | 06:22 PM
If you don't see any chip or cracks that go into the seating area, it is likely bent, from someone having the timing off.
Old Oct 30, 2013 | 11:30 PM
Vmax's Avatar
Cheap gas on top of other worse case scenarios?
Old Oct 31, 2013 | 01:50 PM
ES6T's Avatar
Timing that is off enough to hit valves would hit more than one valve.
Bad gas would affect all cylinders.
If you had coolant leaking in that cylinder, the combustion process was likely affected in one way or another. If that causes crap to build up on the valve, it can damage it.
Old Oct 31, 2013 | 03:40 PM
Chrispy_T's Avatar
I have 1 slightly low cylinder and it has crud built up on it. That's EXACTLY what kills intake valves like that.
Old Oct 31, 2013 | 07:59 PM
gdog's Avatar
Bingo; what ES6T said!
Besides after that many miles, you really need to analyze it? Was the coolant leak on the intake side per chance?
Old Oct 31, 2013 | 10:36 PM
Valid points. Couldn't really tell which side the coolant leak was from after looking at the old gasket. Don't really need to analyze, just kind of curious.
09XC90
May 25, 2011 07:13 AM
Gmanpumps
Jan 13, 2011 05:34 PM
awindrider
Jul 28, 2010 09:45 AM
awindrider
Jul 23, 2010 06:26 PM
lockman
Apr 13, 2010 08:58 PM
