Hesitation on upward terrain
Old May 6, 2011 | 01:49 PM
ABVO850's Avatar
Default Hesitation on upward terrain
Whenever I drive my 94 850 turbo on an upward road, it seems like the car looses power then comes back to and repeats until I give it more gas. I am wondering if this could be due to the fault codes that I pulled from the OBD2 which said Bank 1 Lean and O2 Sensor Heat Circuit Fault Bank 1.. or something else. I plan to change the plugs regardless but any insight would be helpful. Are there any lower priced sources for buying new O2 sensors than Advanced Auto Parts? Is the Bank 1 O2 sensor located in front of the motor? My guess is that the O2 sensor is far gone because the check engine light bulb is blown out along with a bunch of other indicator bulbs meaning its been on for some time now..
Old May 6, 2011 | 03:12 PM
I don't think you should get your O2 sensors from Advanced Auto. Search the pages to see where people get them. If you don't get OEM sensors, get used ones from a junk yard.
Both O2 sensors are on the exhaust. One before the cat and one after.
A lot of people pull the cel bulb when they sell the car so there might not be a bulb in the socket.
You may be loosing power under a LOAD because your wires are worn/faulty. How old are the wires? If they are oem wires, they have a date on them. Month and year.
Also check your vacuum lines.
Old May 10, 2011 | 10:03 PM
ABVO850's Avatar
The plug wires are OEM volvo and say (02 06) on them. Is that Feb 2006 or June 2002? I guess that I will start with my spark plugs and see if that helps..
Old May 10, 2011 | 10:07 PM
I apologize. The wires have the week / year. So your wires were made the 2nd week of 2006. They should be good unless you have over 100k on them.
Old May 11, 2011 | 10:13 AM
_HighVoltage_'s Avatar
Hmm...I never thought that plug wires can create this kind of problem. Can anyone verify that? If it really is possible, then I might have to change my wires too.
I have been experiencing a very small hesitation going up on hills. It's so small that when other people drive my car they don't even notice it.
ddavis5010
Jun 19, 2014 07:24 PM
stonepa
May 22, 2011 08:54 PM
kpiskin
Feb 15, 2006 06:04 AM
s40volvoH
Mar 18, 2005 06:43 PM
knight rider
Jan 10, 2005 12:58 AM
