Hesitation and vibration at 1000 to 2000 RPM???
Old Nov 14, 2006 | 03:13 PM
Viraaj's Avatar
Default Hesitation and vibration at 1000 to 2000 RPM???
I have a 1995 Volvo 850 GLT with an NA engine. It has 74k on it and for sum reason if i press the acceleratior really lightly and let the engine rev from 1000 to 2000 RPM, u can fell the car shaking a bit. after 2000 RPM there is no vibration or anything. Anyone know what the problem is? I have replaced oil filter and checked the spark plugs, they are still usable.
Old Nov 14, 2006 | 10:03 PM
Default RE: Hesitation and vibration at 1000 to 2000 RPM???
Engine mounts good?
Old Nov 15, 2006 | 02:56 AM
JPN's Avatar
JPN
Greetings from Chicagoland.
Take a look at FCP Groton's parts illustration at the following URL:
http://www.fcpgroton.com/volvo850mounts.htm
Find an engine mount numbered 9135178. This one seems to get tired more than other mounts. Check to see if it's rubbing against the sub frame. I just bought one for my 850 and plan to replace it asap. Also, check other engine/sub-frame mounts for deterioration/damage.
A complete ignition system tune up is not done until you replace distributor cap & rotor, and ignition wires. In some cases, ignition coil is replaced as well.
Is your fuel system good? Have you replaced the fuel filter lately? What about the air filter?
It's probably the engine mount (s). If it's the engine itself that is causing the vibration, the RPM should be erratic.
Good night,
JPN
Old Nov 15, 2006 | 05:35 PM
Viraaj's Avatar
Checked the engine mounts they look perfect. And I let a mach look at it also he said they were fine. But not sure about the ignition system
jwvolvo
Apr 5, 2013 10:04 PM
Johnny Volvo
Nov 27, 2012 01:05 PM
leppya
Jun 5, 2011 01:20 PM
goatboy311
Jan 11, 2010 07:43 AM
ocean238
Apr 17, 2008 06:20 PM
