Hesitation when accelerating
Old Nov 3, 2007 | 03:23 PM
oldbug's Avatar
Default Hesitation when accelerating
I've got a '93 850 automaticwith a new issue! The car idles and starts fine, but, when I step on the accelerator quickly, it 'bogs down" for a few seconds, and , than revs up.It does this whether I'm in neutral or in gear. IfI step on the gas pedal lightly, it's not a problem!
I just changed the coolant, and, replaced the coolant temp sensor thinking it might be the problem, but, it wasn't.
Any suggestions are appreciated!!
Thanks, Tom
Old Nov 3, 2007 | 03:26 PM
axelm's Avatar
Default RE: Hesitation when accelerating
Any codes?
Old Nov 4, 2007 | 08:21 PM
oldbug's Avatar
I checked the codes today using the on-board system. Here's what I got!
Fuel System Fault Codes were 1-2-1 ( MAP sensor signal absent or faulty) and1-2-3(Coolant Temp Sensor signal absent or faulty)
Ignition system FaultCode was1-2-3(Coolant Temp Sensor signal absent or faulty).
I just replaced the Coolant Temp Sensor! I ,also, checked the voltage @ the terminals and it was 5V per spec.
I ,also, removed the connector from the MAF while the car was idling, and, it stalled! Is thisnormal??
Any suggestions??
Old Nov 4, 2007 | 08:27 PM
It should run with the MAF unplugged the computer goes into "Limp Home mode" and should run.
Old Nov 5, 2007 | 03:40 AM
axelm's Avatar
Clear the codes and see which one comes back.
blackie740wagon
Aug 31, 2010 12:52 PM
dutch connection
Feb 8, 2009 01:25 PM
volvo13
Apr 24, 2006 09:14 PM
meerkat
Sep 8, 2005 08:22 AM
Jutboy
May 24, 2005 01:15 AM
