Hissing noise
Old Sep 21, 2007 | 10:35 PM
xxjoeyxxeb's Avatar
Default Hissing noise
Hey guys,
Just bought a 94 850turbo sedan. 136K. There is a constant sssshhhhhhhh noise coming from in front of the left front wheel. Any ideas what it could be?
Thanks,
Joe
Old Sep 22, 2007 | 12:12 AM
mrpyromaniac's Avatar
Default RE: Hissing noise
By left front you mean drivers side? Your air intake is right there. Check the bottom of the air intake and make sure there are no leaks, also check the hose running to the front of the vehicle. Assuming you are hearing this sound while the vehicle is parked and running lol.
Old Sep 22, 2007 | 10:50 AM
JPN's Avatar
JPN
Hi Joe,
Welcome to the forum, I hope you find it useful & enjoyable.
As to the hissing, if it's on the driver's side it is likely that the source is somewhere along the intake or turbocharger. Visually inspect the plastic tubes for cracks, disconnected portion or loose clamps. Also, check the small vacuum elbows that are known to fail after years. They are usually under the throttle housing cover, which is held in place by one Torx screw.
Good luck,
JPN
Old Sep 22, 2007 | 12:37 PM
xxjoeyxxeb's Avatar
Hey,
Thanks guys, I will check it out today. It sounded like a leak or a blockage to me last night. And yes this was while parked and running.
Just FYI, automotive industry uses left and right instead of driver and passenger side. And that is while looking from the back of the vehicle.
Old Sep 22, 2007 | 10:09 PM
RedTurbo850's Avatar
Sounds like it's a boost leak.
How far does your boost gauge go?
Old Oct 3, 2007 | 04:05 PM
phoenix_iii's Avatar
ORIGINAL: RedTurbo850
While parked and running?
s70_t5_1999
Aug 30, 2009 07:15 PM
Calita03
Feb 23, 2009 05:58 PM
akorcovelos
Jan 16, 2009 09:48 AM
rchen404
Nov 11, 2008 07:34 PM
kaz
Jul 7, 2006 01:11 PM
