How to check speed sensor pulse signal
Old 06-23-2008 | 12:05 PM
RomoGuy's Avatar
Default How to check speed sensor pulse signal
Does anyone know how to check the Speed sensor pulse signal going to the cluster on a 95 850 GLT?
Old 06-23-2008 | 07:50 PM
Default RE: How to check speed sensor pulse signal
You should be able to test with an Ohm meter.
Old 06-24-2008 | 12:40 AM
RomoGuy's Avatar
how would I do it? would the car have to be on??? and do you know what kind of voltage i should be getting from it?
Old 06-24-2008 | 06:53 PM
If you Ohm it then Put it in gear and watch the meter and see if it moves.
I would have to try to look the spec's up for voltage.
mr.Bean240
04-13-2012 04:22 PM
shuv70
07-11-2009 02:04 PM
quarterdimenickel
02-10-2008 08:28 PM
jvcski
02-06-2008 09:37 AM
gl1970
08-28-2007 03:40 PM
