How Do I Remove A-Pillar trim?
Old Dec 14, 2008 | 07:37 PM
m1964's Avatar
Default How Do I Remove A-Pillar trim?
I am planning to install a Parrot kit into my son's 850- I will need to run the michrophone cablefrom under the dash up the a-pillar to the overhead lights -need to remove a-pillar trim and then overhead lights/plastic panel .
Anyone can help?
thanks a lot
PS
the car is 14 y. old and am afraid to break plastic trim ifremoved wrong way.
Old Dec 14, 2008 | 08:41 PM
Default RE: How Do I Remove A-Pillar trim?
It pretty much just pulls off. Easiest way is to pull down the seal first then slide fingers in and pop it off.
Old Dec 18, 2008 | 11:38 PM
m1964's Avatar
Thank you,
tech-
can you tell how to remove overhead console ?
thanks
Old Dec 19, 2008 | 06:36 AM
Adrenalin540's Avatar
Pop off the two light covers with a screwdriver or plastic pry tool. Then you will see 2 small torx bits screws in the light openings 1 in each opening, back out those 2 screws and carefully pull it out. Nothin to it...
Old Dec 19, 2008 | 08:11 AM
ORIGINAL: Adrenalin540
+1
Old Aug 13, 2012 | 04:52 PM
tjsully's Avatar
Tech, I also need to pull off the B pillar covers too, the material is coming off and I'd like to reglue it down. It's making my S80 look pretty bad. Also any advice on what kind of glue to use to glue the headliner like material back on to the pillars?
Old Aug 13, 2012 | 07:30 PM
ibified's Avatar
btw: the two screws you have to remove for the overhead console are #10 torx. If you dont already own a set of torx bits and you plan on doing work on your volvo, you need to buy a set.
tbo_cruiser
Sep 7, 2023 01:34 PM
hovonogila
May 16, 2019 02:28 AM
bocarat
Jul 8, 2016 08:17 AM
01S80T6USA
Apr 9, 2011 11:24 AM
contsi
Apr 19, 2009 09:29 PM
