How to install an aftermarket Muffler??
Old Dec 15, 2011 | 12:11 PM
papabeardoe's Avatar
Default How to install an aftermarket Muffler??
Ok first thing I went pretty far into the threads and I didnt see anything about this. I have looked underneath my car and all I see is straight pipe. I want to install a muffler but unlike other cars my volvo doesnt have anything that I can just unattach and just attach the aftermarket one. Can someone steer me in the right direction on what to do. Am I suppose to cut pipes and solder other ones or something like that? Please help. Here are some pictures to help you understand what im trying to say.
Old Dec 15, 2011 | 01:00 PM
gilber33's Avatar
Put the muffler in the back seat. Drive to exhaust shop. Give them car, muffler, credit card. Done.
Unless you can weld.....
Old Dec 15, 2011 | 06:24 PM
MattyXXL's Avatar
+1 with gilber... A muffler shop would be your best bet..
But if you have a turbo you can go with an OBX for $350
Fairly simple to install, but ALOT easier if you have a lift, doing it on your back sucks *****!
Old Dec 15, 2011 | 10:49 PM
boxpin's Avatar
Gabe, you crack me up.
Old Dec 16, 2011 | 11:08 AM
Locate problem, cut pipe, replacement might slip on and can be clamped, you can take replacement to muffler shop and they can expand or contract the end for a slip on fit and clamp (you have to supply measurements), go to parts store and get adapters to fit the replacement (you need to know the size, they usually can't look it up) to the existing pipes and clamp or weld or take it to someone and have them weld it in place.
That's the easy answer, if you have a Volvo and the muffler goes bad and you want to do it yourself you have to be smarter than the car because it's not a straight shot. Auto parts stores sell 45 and 90 degree bends and if you spent more time playing with an erector set or Lincoln logs than play station three you have better "skills" for piecing it together.
If you've seen the replacement for our muffler you see it comes as one big piece and because it does the catalog doesn't tell the pipe sizes because you buy it all together. That's why the guy at the parts counter usually can't help you with a part like this for the pipe size. They don't tell him.
Exhaust pipe cutter is a loaner tool from Oreilly, Autozone ....
Attached Thumbnails How to install an aftermarket Muffler??-exhaust-pipe-cutter.jpg   How to install an aftermarket Muffler??-exhaust-pipe-adapter.jpg
Prince80
Jun 12, 2015 06:50 PM
jdbs3
Mar 8, 2009 04:52 PM
chef
Jan 28, 2009 10:23 PM
740drifter
Dec 29, 2006 11:59 PM
850_Wagon
Dec 4, 2006 10:03 PM
