View Poll Results: A poll
I had to replace the evaporator
33.33%
I had to replace the receiver/dryer or accumulator
0%
A/C failed, but not because of the evaporator or reciever/dryer
0%
I've been lucky; A/C is still working fine
22.22%
I do not know, I wasn't the only owner, don't know about past repairs
44.44%
Voters: 9. You may not vote on this poll
How many had to replace their evaporator?
Old Jun 29, 2006 | 05:45 PM
wheelsup's Avatar
Default How many had to replace their evaporator?
Hi!
I have a 95 850 and the a/c has gone ka-put. Last year I finally found what I thought was the problem - the reciever/dryer was rusted out from the bottom. I know that these cars have a tendency to fail at the evaporator level as well, and I have no idea it failed as well. The car had a yellow dye put in the system but I only saw dye coming out of the receiver/dryer, I would have no idea where it would be visible if the evaporator failed. Any ideas?
Also, I created this poll to see just how many people have had problems with their a/c and what that problem was. If you do not know IF something was fixed please don't answer choice number 4, use choice number 5.
The point of this is to see if I even stand a chance of being lucky if the evaporator has survived 11 years without rusting, or if I'm replacing the reciever/dryer in vain...
Thanks!
Old Jun 29, 2006 | 08:59 PM
Default RE: How many had to replace their evaporator?
If you have a black light I can tell you an easy way to see if it is leaking.
It will take you about 1/2 hour to see if it is leaking.
Old Jun 29, 2006 | 09:31 PM
wheelsup's Avatar
Ok thanks! If I can get the accumulator off and fixed I found a garage that will vaccum out the system and put oil in it for $90. I told him I would just add the refridgerant myself to save some $$ so I'm guessing you'll have me put 'special' UV refridgerant in? That makes sense.
Anyhow one step at a time!
And for those who didn't repond to the poll, c'mon, 16 hits and no responses...
Old Jun 29, 2006 | 11:33 PM
If you had Dye in there already if it is leaking Dye will be there now.
All you have to do is remove the Glove box insert. Then the Metal Knee bolster. Then look in and you will see a Black Resistor bolted in the Box with one T-15 screw. Remove it and look in to the right and you will see the evaperator. With the Black light you will see the Dye really bright.
I will bet it is leaking. Most cars it only lasts about 3 years.
In the last 6 years I have to have done a couple of hundred Evaperators.
Old Jun 30, 2006 | 11:50 AM
JimKW's Avatar
How much does you shop charge to do replace the evaperator?
Old Jul 1, 2006 | 09:33 AM
I believe it is a little less than $1000.00 for the Job.
Parts are like #300.00 and Labor is about 10 Hours. We are the cheapest in our area for labor. We are at $68.00 an Hour. The Dealer is at $98.00 an Hour.
jakefitz
Mar 31, 2009 02:38 PM
diehardgator1
Sep 9, 2008 06:52 PM
1990TURBO740
Dec 25, 2006 04:23 AM
robert213
Aug 26, 2006 04:32 PM
tech
Jun 18, 2006 02:40 AM
