How much boost will 'R' ECU allow?
Old Jan 1, 2012 | 11:41 AM
trackstar's Avatar
Default How much boost will 'R' ECU allow?
Happy new year! Searched this high and low to no avail. Stock 850 turbo makes 9.6psi. R's make about 10.6psi or so I think. Does anyone know how much the stock ECU and the R's ECU will allow before fuel shutoff if I tinker with boost pressure? Thanks
Old Jan 1, 2012 | 04:32 PM
91shelby's Avatar
15psi if im not mistaken
Old Jan 1, 2012 | 05:48 PM
clean850R's Avatar
R can control 14.5psi with no issues! I run mine at 14. Occational flare to 15 then settles to 14! Remember too the wastegates are different on both models. Need to set waste gate properly to prevent over boosting! No sure what a stock one can handle would assume maybe 12-13 no issues?
Old Jan 2, 2012 | 10:50 AM
MattyXXL's Avatar
I still wouldnt run 14 psi on a stock ecu without a AF gauge,
you need to watch how lean you are running
endneu913
Mar 28, 2010 11:41 PM
saltman241
Aug 21, 2007 11:15 AM
S70driver
Dec 6, 2006 01:53 AM
luke8_8
Sep 8, 2006 04:52 PM
nmc
Jan 20, 2006 08:47 PM
