how much does the abs sensor effect???
Old Dec 4, 2010 | 12:50 AM
MMasberg's Avatar
Default how much does the abs sensor effect???
So there are a few things going on with my car...
i have read a ton of threads and i understand that my speedometer and odometer problems are being caused by the module going out. Also, the traction control doesnt work the best and the anti lock brake system kicks in pretty often even when i dont need it...
but... tonight, it snowed about 3 inches. its about 24 degrees out. i started the car and i let it run and warm up for about 10 minutes. the temp gauge was reading at mid range. i got in to back out of my parking spot and as the tires slipped in the snow( wasnt pushing it hard) the abs light came on then all the warning lights and the car turned off. i put it in park, started it back up, put it back in reverse and it did the same thing two more times. i played around with the winter setting and i pulled the rest of the way out. switched off the winter setting and drove all the way home with no problems..
i used reverse again a few times since then without any problems. could that be part of the abs sensor?\
thanks a ton
laser99
Nov 16, 2011 09:47 PM
SteveinAZ
Feb 11, 2010 03:15 PM
dman777
Jan 23, 2008 12:08 AM
b5254t
Oct 25, 2007 04:39 PM
LillyWhite
Sep 2, 2005 04:24 PM
