Does a wash effect it THAT much?
Old Jul 24, 2005 | 07:26 AM
LillyWhite's Avatar
Default Does a wash effect it THAT much?
Hi all
Sunday morning and all was well with the world.
I washed me car yesterday (2002, S60 D5) and it looks NICE.
But, when I come to use it this morning I turn the key and all hell breaks looses - engines turns over reaaaallll slow a couple of times then stops, headlights flashing and a ticking noise (quite loud) from engine. All lights internally are flashing - fuel indicator says 999999 miles to empty, then it says Brake Failure stop safely (lol!) and then Engine Service, all the while lights are flashing and that annoying ticking sound.
I know I did not leave the lights on (or anything else for that matter) so WTF??
Had two dipped beam bulbs go in last 2 months, and it told me a parking light had gone (it had - it was not working) but then, a day later it decided it was (and it was) working fine!!! Every so often when driving I would get a loud beep from the system and a secondary (like split second) loss of power and it would carry on - is all this related?
I am in NO WAY a car expert but it *sounds* like an electrical problem to me lol.
Any pointers? Ideas, feedback or is it foobar'd?
Old Jul 24, 2005 | 12:36 PM
Default RE: Does a wash effect it THAT much?
Sounds to me like the battery went bad.
Most likely you will need a new one.
Old Jul 24, 2005 | 02:19 PM
LillyWhite's Avatar
Cheers tech.
Hmm - when I switch it on, the radio plays (but only comes out of central speakeron dash) and the system messages display then fade.
What can cause a battery to fail like that?
I guess I will be contacting ye olde Volvo garage in the mornin' then
Old Jul 24, 2005 | 02:27 PM
The batteries are the most unpredictable item in the automotive world.
They could work fine one minute and then be totaly dead the next minute.
Try to get a jump start and see if it starts.
Old Aug 9, 2005 | 12:20 PM
S60T55SPD's Avatar
I replaced a bulb yesterday (position light) - warning light went out - then back on this morning - then went out on the way to work! You're not alone in that area
Old Sep 2, 2005 | 04:24 PM
radthes's Avatar
It seems like an original battery problem. Had the same with my previous car, and solved it in 5 minutes by changing the battery. In our days batteries could die in less than 3 years!!!
laser99
Nov 16, 2011 09:47 PM
MMasberg
Dec 4, 2010 12:50 AM
SteveinAZ
Feb 11, 2010 03:15 PM
dman777
Jan 23, 2008 12:08 AM
b5254t
Oct 25, 2007 04:39 PM
