How to test ECC on 1996 850
Old Oct 2, 2008 | 11:43 PM
thedawgfather's Avatar
Default How to test ECC on 1996 850
How do I test the Electronic Climate Control on a 1996 850 GLT? Some connection of an LED to pins in the OBDII port? My main problem is that the compressor switches on and off continuously when I run the A/C and the air never gets cold, because the compressor is never on, it's just cycling on and off every couple secs or so. I recharged the system and have checked the pressure and it is within normal limits.
I appreciate any help, thanks.
Old Oct 3, 2008 | 05:08 AM
Default RE: How to test ECC on 1996 850
The high pressure switch might be bad not allowing the cooling fan to come on.
Are the lights flashing when you start the car?
Old Oct 3, 2008 | 10:46 AM
autoxray's Avatar
Tech
What does it mean when the lights flash at start up?
Old Oct 3, 2008 | 01:00 PM
That means there is codes stored in the ECC module.
dksoutha
Feb 25, 2013 04:41 PM
96960Chris
Jun 25, 2010 03:43 PM
ikes4ever
Mar 25, 2010 07:25 PM
richsid
Mar 25, 2008 01:01 PM
willko1
Dec 13, 2005 01:38 AM
