Hub Assembly Replacement
Old Jun 28, 2006 | 03:19 AM
tm_94altima's Avatar
Default Hub Assembly Replacement
Well my driver side hub assembly is shot and I've got a new one on the way. Any advice or knowledge would be good before I start this project. Does anyone know of any other materials or special tools I need to get other than the new hub assembly?
Old Jun 28, 2006 | 09:44 PM
Default RE: Hub Assembly Replacement
Have you done an Axle before?
Old Jun 29, 2006 | 03:35 AM
ORIGINAL: tech
Replaced one? Not on my car.
Old Jun 29, 2006 | 08:36 PM
It will be pretty easy if you have done one already.
Loosen the 2 Hub to strut bolts, the sway bar link, The ABS sensor, and Axle nut (36mm).
Then tip towards you to get the axle out. Then go from behind to remove the Hub Bolts. Or you can also remove the balljoint nut and remove the caliper and remove the hub from the car.
You will need an Inverted torxes socket to remove the hub bolts. I forget the size. Most Auto parts stores sell the sets for pretty cheap.
puxnstx
Dec 13, 2014 11:36 AM
rmurray
1998-2000 model year V70
Nov 11, 2013 09:55 AM
mirubbish
May 10, 2007 12:38 PM
ibmkillr
Nov 2, 2006 10:56 PM
adub96
Aug 11, 2006 10:40 AM
