Wheel Hub Assembly
Old Aug 8, 2006 | 01:50 PM
adub96's Avatar
Default Wheel Hub Assembly
So I think my front wheel hub assembly is going bad. Because its making the wubba wubba wubba sound when i make turns. But I see that the going rate for a replacemnt is in excess of $150. I was wondering if any of you guys have a spare one sitting around or know a good place to get one for the s60 2.4l non turbo? Is it possible to just get the bearings and press them in myself. Thanks for the help.
Old Aug 8, 2006 | 04:09 PM
adub96's Avatar
Default RE: Wheel Hub Assembly
Also is the hub pressed into the spindle? Or is it held on just by the end bolt? And what are the years of cross refrence and motor crossing, for example could I use the hub assembly from a 2004 s60 2.4t. hope this isn't too technical, buti'm sure someone knows.
Old Aug 8, 2006 | 08:43 PM
They are not Press in bearing they are screw in assembly's.
Are you 100% sure it is the bearing and not the tires?
Old Aug 9, 2006 | 02:19 PM
adub96's Avatar
Yeah i thought it might be the tires at first myself. But i every tire even the spare made that noise up on just that corner. I've been looking around I'm going to purchase this used one for 50 bucks and try it out. I figure worse thing I at least will have a spare part if it doesn't work. Other than that the volvo rocks, except for that intermittent turn signal not working, then working depending on temperature.
Old Aug 9, 2006 | 08:47 PM
Turn signal is either the Stalk is bad or one of the front Sockets for the Bulbs.
Old Aug 11, 2006 | 10:40 AM
adub96's Avatar
Its the front socket, i have tried dielectic grease (sp?) and that didn't work so i changed the sockets, switchedleft to right then the other side didn't work. I noticed it was made in France so i chocked it up to being French and the lack of wanting to comply with any one else from the EU.
puxnstx
Dec 13, 2014 11:36 AM
Miles of Lief
Oct 18, 2009 09:05 PM
Lagarto888
Jul 5, 2009 05:06 PM
mirubbish
May 10, 2007 12:38 PM
tm_94altima
Jun 29, 2006 08:36 PM
