I can haz moar 850? May pick one up. Has issues
Old Aug 18, 2011 | 12:45 AM
VJZ's Avatar
VJZ
Default I can haz moar 850? May pick one up. Has issues
So I found an 850 project.
I need a refresher as its been a while.
Here's the scoop: 1994 Turbo wagon. Tan on tan. Body has 245,000 miles. Exterior is IMMACULATE. I cannot stress how amazingly clean it is. Inside is perfect except for the driver's seat having a rip. Supposedly has an engine with 89,000 miles.
Won't start. Cranks, but no start. Owner states it will run and then die after a while, and then after a few tries of starting it runs fine. Battery is almost shot.
Fuel pump relay? That's my first thought. Maybe the PNP switch?
Next is a relay by the fan in that little section by the front of the car. It buzzes REALLY loud. I'm not sure what it's for, but its gray and I believe has the number 508 somewhere in its part number. I have a pic of it, but that would require me to get out of bed and go over to my phone to upload it, and I am too lazy for that.
Then, the Winter mode triangle sometimes flashes. I almost think its the transmission S/E/W switch, as the WINTER button is stuck from crumbs, dust, and food. Or, what else could it be
From a visual inspection, the body is like a 9.9999999 out of ten. Only flaw was it was missing the driver's headlight wiper blade and fender VOLVO emblem. Both of which I have in a box in my basement.
Tires were decent, rotors looked relatively new, and I would assume pads are newer too, unless they were total cheap asses and didn't change pads.
$800 cash
Gimme yo thoughts
Old Aug 18, 2011 | 09:52 AM
boxpin's Avatar
SNAG THAT!
You know that will be an easy fix, just need the find the problem. Most likely fuel issue, pump or relay. I would lean towards the pump.
Old Aug 19, 2011 | 01:10 PM
jks2's Avatar
$800? Jump all over that bad boy.
Old Aug 19, 2011 | 01:56 PM
trs80's Avatar
1/4 million miles and looks like a 9.9/10?
Pics or BS.
Old Aug 19, 2011 | 05:02 PM
He said it has 89,000 miles or less. If the trip odo is 0000 then the odo is likely broke, and you should check the mileage at the odb-1 port. If it's that clean it's pro ably correct mileage. The relay @ the fan is for fuel injectors, the pump relay is inder the fuse box.
Old Aug 20, 2011 | 05:46 PM
trs80's Avatar
Said body has 245k miles, used engine put in has 89k miles.
Old Aug 21, 2011 | 01:39 AM
ibified's Avatar
I went with him to look at the car, and I can definitely attest that it's in damn good shape...I'd give it a 9 out of 10 easy.
ScottRod
Apr 25, 2014 09:28 AM
marsilver
Oct 15, 2010 09:12 PM
