I think my serpentine belt is going out
Old Aug 11, 2010 | 05:05 PM
MC92's Avatar
Default I think my serpentine belt is going out
It seems every time I turn on my ac there is a slight chirping sound going on very faintly lately and I just replace my alternator and the electrical problems are coming back again after a month. Just this morning I would start the car and it barely started like the battery was dieing and it's new. Later after work the radio would cut out and I think the the service, abs, or tracs came on briefly since it flash so fast I couldn't tell what it was. After I got home I turned the car off and move the key into position II and nothing would light up. Had to do it a couple times and then it would show the lights. I did check the belt for glazing or cracks, but it's fine.
Old Aug 11, 2010 | 05:15 PM
ibified's Avatar
could be a belt tensioner thats going bad. Check that first, and replace it if it's bad. I'd also spend the 20 bucks and get the replacement serpentine belt.
Old Aug 11, 2010 | 06:39 PM
fcpgroton's Avatar
Former Sponsor
It could be just the belt, but I would replace the tensioner also just to be sure. Them normally go out around the same time anyway.
Old Dec 29, 2010 | 09:50 PM
s40volvo's Avatar
I just had the AC tensioner changed on my 05 S40 but I still have a chirping noise thats rarther loud. Could it be bas belts? I've noticed that my S40 has two belts. One is AC Compressor to Alternator. I have to look at the other one what it's connected to.
I thought the chirping was more like a metal noise but the mechanic mentioned that it is most probably the belts. Could that be true?
Old Dec 29, 2010 | 10:09 PM
ed7's Avatar
ed7
You could be hearing the A/C clutch chirping from too large of a gap or scorched bearing.
Search for the ever-popular bread clip adjustment I've heard so much about.
Ed
Old Dec 30, 2010 | 06:44 AM
s40volvo's Avatar
Ed
I just had the compressor changed so I'm eliminating the bearing possibility.
I'm thinking probably misalignment of pulleys?
OR
Bad belts
OR
A combination of both
My belts seem pretty shiny (mechanic said shiny is not good) and I should probably try fixing the belt with the nice Dayco one.
Old Dec 30, 2010 | 09:47 AM
I have never heard of a belt causing a problem. Pullies, rollers, and other items may damage a belt, but not the belt itself. It's just a piece of rubber. A victum in the path. They get old, crack, and break, not cause problems.
Take the belt off, takes about 15 seconds, then check the items in the path. How smooth does items turn? If the belt is old and maybe has been contaminated with some kind of fluid like oil or something, maybe it needs replaced. Other than that, it's a componet in the path.
Psaboic
Jul 30, 2014 10:07 PM
Tim Sway
2001-2013 model year V70
Apr 12, 2013 10:43 PM
Psaboic
Jun 18, 2011 11:36 AM
iscwebe
Feb 9, 2010 12:50 AM
Royalty
May 16, 2008 06:45 PM
