I took the plunge and made my 1st Volvo purchase
#21
You'll be spending days cutting that thing out. Follow the cdnbluez link. I use Hole saws to press it out. One the size of the bushing the other bigger that fits over the bushing then a long threaded stud and bolt to move them. Sort of hard to explain typing but it works really really good and the whole job is done in about 5 minutes.
#22
So I guess what your saying is there is no metal sleeve the OEM bushing is attached too. This should be even easier than I thought. I was thinking the OEM bushing rubber part was surrounded by a metal sleeve and then pressed in tp the upper mount. Sounds like from reading the link provided (thanks cdnbluez) it's only hard plastic.
#23
#24
Turbo Matt: Congrats, you da man now dog!!! I was actually thinking about selling my Yellow T-5R for one of those '98 V70R (rust color).
That top mount is easy. I think there is metal on the rim of it but I just tore it out after I cut the rubber out. I think I used a hack saw, the removal process took less than 10 minutes. I cut out the rubber then wedged a smaller flat tip screw driver under the metal, bent it inward and tore it out. I put in the poly mount from IPD but it does add vibration into the car.
http://www.ipdusa.com/Volvo-S70V70-P...8-364-763-229/
I would replace that mount as soon as you can. You can drive the car but I would NOT put my foot in it. That mount plays a big role in keeping that motor in place and you will learn that the car has a heck of a lot of torque, good mounts are very important.
If you feel any hard shifting, say from 2nd to 3rd. You will likely need the lower torque/transmission mount. I put the ipd heavy duty mount there as well. And yes it also added a little more vibration. You really only feel the vibration at low speeds, say under 25 mph.
The other motor mount that fails A LOT is the front motor mount. The one behind the passenger side wheel. Here are my instructions for that one.
http://www.atthetipwebs.com/technolo...ount_right.htm
As for the seats, that material is not real suede so any upolstry cleaner should work fine.
Is the rear axle still in place?
#25
IL guy
11-16-2009 05:15 PM
