idle ?
Old Jun 6, 2008 | 05:03 PM
je850's Avatar
Default idle ?
I am idling at 1000 rpm and it wont adjust down.
Old Jun 7, 2008 | 05:29 AM
JPN's Avatar
JPN
Default RE: idle ?
Check for:
- Fault codes in the ECU.
- Vacuum leak.
- Throttle body clean.
- Throttle cable adjustment.
- Other members' advice.
Also tell us what trim model you have; turbo orNA.
JPN
[IMG]local://upfiles/6892/164BCD607EDA47569F7437D2CF70DEF8.jpg[/IMG]
[IMG]local://upfiles/6892/6D0F29B3E5374C2DA7669730882F212D.jpg[/IMG]
[IMG]local://upfiles/6892/ED04A4C79E4C492F9933A830A40AB808.jpg[/IMG]
[IMG]local://upfiles/6892/D81820149CD3457DBE5FF71192498EDE.jpg[/IMG]
Old Jun 7, 2008 | 10:08 AM
je850's Avatar
Default RE: idle ?
Sorry 1997 t-5 with 90000 mi. I have cleaned the throttle body and there does not seem to be any more adjustment but the car runs great. cant find any leaks thanks
Old Jun 7, 2008 | 10:12 AM
je850's Avatar
Default RE: idle ?
Just looked at the diagram and it shows an idle stop cant tell from the pic if thter is a adjustment it looked like the rod was the only adjustment
Old Jun 7, 2008 | 10:14 AM
Default RE: idle ?
Clean the idle motor.
Old Jun 7, 2008 | 10:46 AM
Systek's Avatar
Default RE: idle ?
i'd leave the idle stop alone...once you adjust it, the ecu has a hard time adjusting itself.
Old Jun 7, 2008 | 11:45 AM
je850's Avatar
Default RE: idle ?
JNP thanks for the info was looking at the first diagram and the first thing it says to do is the tps switch but it does not show it in the diagram
Old Jun 7, 2008 | 12:53 PM
JPN's Avatar
JPN
Default RE: idle ?
Follow Tech's advice. Then, visit a local Autozone/other parts shops that provide free OBD-II diagnostic services and have them pull codes with a decent scanner.
JPN (or was it JNP?)
[IMG]local://upfiles/6892/8920B4BA22BD4976B2936579877D4A25.jpg[/IMG]
[IMG]local://upfiles/6892/4D10E25300934BE0BC89E07744964279.jpg[/IMG]
[IMG]local://upfiles/6892/B092653D0CDD4AD0A17F71F57B7673F0.jpg[/IMG]
[IMG]local://upfiles/6892/9584E117C5224029996DB2FABB34F9FD.jpg[/IMG]
Old Jun 7, 2008 | 12:55 PM
JPN's Avatar
JPN
Default RE: idle ?
The more, the better approach (but these tests would probably drive you nuts).
JPN
[IMG]local://upfiles/6892/7713F7BCAE5147DDA105392F566858A6.jpg[/IMG]
[IMG]local://upfiles/6892/8B6174CE6A4C436B8C455D107A9D964D.jpg[/IMG]
[IMG]local://upfiles/6892/04D87294DCF740038B2730A267818DB7.jpg[/IMG]
matt01
Dec 4, 2011 10:53 AM
rosesforlily
Nov 5, 2009 09:23 AM
kevmcrae
Apr 25, 2009 11:25 PM
yank50
Mar 14, 2009 11:15 AM
ss~zoso~ss
Jan 12, 2009 04:27 PM
